First sub amp. Plate or sepatate???
Discussion in 'Archived Threads 2001-2004' started by Joel Grice, Feb 8, 2002.
  1. Joel Grice
    Joel Grice Extra
    Feb 8, 2002
    17
    Hello all,
    This is my first post and my first project (a sub). I was wondering if I should use a plate amp on the back of the box or get a separate amp to look pretty on my rack?
    I am leaning towards a separate amp, but they're so much more expensive. What are your thoughts/experiences?
    Specific model reccomendations are also welcome. I need 100 - 200 watts.
    http://cgi.ebay.com/aw-cgi/eBayISAPI...tem=1331490479
    As you can see, this amp is so inexpensive it's hard to pass up. Apex Jr. sells another Audiofile model.
    Joel
  2. If all you need is 100-200watts, go with the plate! It would be far cheaper and make life easier.
    Most of us that go with pro-amps are using atleast 500watts ..to upwards of 2000watts.
    BUT!!!!...that amp you showed from e-bay isn't worth the UPS postage you'll have to pay to get it! It can probably do 100watts with 99% distortion!
    spend a little more and get a much better plate amp.
    120W SUBWOOFER AMPLIFIER @ PE for $99
    AMP130 @ stryke for $89
    ...and you already know about the apex jr.
