First Home Theater - Energy Take 5.2's or AR HC6
Discussion in 'Archived Threads 2001-2004' started by Rex G, Nov 23, 2001.
  1. Rex G
    Rex G Auditioning
    Nov 22, 2001
    2
    Starting to put together an entry level home theater. I've about decided on the following:
    Panasonic Tau 36" HDTV
    Panasonic RP56 Progressive Scan DVD
    Sony STR-DB940 Receiver
    I'm having trouble with the speaker selection. I've heard many great things about the Energy Take 5.2's, but not much about the AR HC6 system? Any recommendations, including the other equipment I'm considering would be greatly appreciated, thanks in advance!
  2. Brett DiMichele
    Brett DiMichele Producer
    Sep 30, 2001
    3,181
    Rex,
    I am sure that you will get a million *glowing* replies
    saying that the Energy setup is the way to go. I can not
    confirm nor deny this. Your best bet would be to hear each
    set IN person and then make an educated decision. I have all
    AR components as far as speakers go and I absolutely love
    them, but I can not say how the HC system sounds as I have
    not heard it.. I can say the Hi-Res series is glorious but
    the HC series may not be.. Give both a listen..
  3. Haris Ellahi
    Haris Ellahi Second Unit
    Oct 30, 2001
    485
    110
    I would look into the Klipsch Synergy line.
  4. Scott Kurl
    Scott Kurl Auditioning
    Nov 28, 2001
    2
    I am in the same boat. I heard the energy system, but was a bit rushed by the dealer and it was on the floor with alot of other things going on. The magazine, The Perfect Vision, has a great review on the HC6 system, glowing actually. I like the idea of the sub size or I think I would lean to the AR's. Good Luck!
  5. Brajesh Upadhyay
    Brajesh Upadhyay Supporting Actor
    Jul 11, 1998
    787
    I got the HC6 for just $500 + shipping from etronics.com after reading that glowing review in The Perfect Vision.
    The speakers are very good. Hard to believe you get such clear & robust sound from speakers that small. I used to own Infinity RS3's, a CC3 & a BU120 -- I like the sound on these better, but speaker preference is a very subjective decision.
  6. RobV
    RobV Extra
    Aug 1, 2001
    20
    Hello,
    I had both the Energy and AR HC-6 Speakers, I ended up with the HC-6. They looked better and to me they were just a little bit clearer, also the sub was by far the better one of the two. Good Luck.
  7. Greg Thomas
    Greg Thomas Second Unit
    May 3, 1999
    438
    Which is supposed to be better between the HC-2 and HC-6? The HC-2 has 5 1/4" woofer on the satellites while the HC-6 had 3.5". Plus the HC-2 has a 12" sub versus the 8 on the HC-6.
    But the HC-6 cost $20 more at Etronics. What gives?
  8. Rex G
    Rex G Auditioning
    Nov 22, 2001
    2
    I ended up going with the AR HC-6 system also. Thanks for all the input! [​IMG]
    Rex
  9. Brajesh Upadhyay
    Jul 11, 1998
    787
    Rex, congrats. I expect you'll be quite happy with the HC6. They're classy speakers -- AR even includes a pair of white gloves so you don't get your fingerprints on the black piano finish speaker casing.
