First DIY sub . Is this a good idea ?
Discussion in 'Archived Threads 2001-2004' started by Chris Davies, Feb 16, 2002.
  1. Chris Davies
    Chris Davies Auditioning
    Jan 9, 2002
    9
    I originaly planned on using a Dayton 12" DVC and this amp . But I have an Infinity 10" KAPPA series from my car sitting arround . Could i use it with this amp , or should I stick to the original plan ?
  2. Travis G
    Travis G Stunt Coordinator
    Jan 6, 2002
    94
    I'll second that. You'll get a few Hz lower with the Dayton and transient response is much better above 50 Hz. You could also spend a few bucks more and get a Shiva.
    I'm going to use that same amp to build a friend of mine a sub so let me know how it turns out.
    Has anyone else used this amp? Is it truly 250 Watts?
  3. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    Travis,
    AudioXpress (formerly SpeakerBuilder Magazine) did a review of several plate amps last year. Of them, this was one. IIRC, it actually is rated a bit on the conservative side with something along the lines of around 280 watts. Don't quote me on this though. I may have it confused with one of the other PE amps in the review.
    Brian
  4. Chris Davies
    Jan 9, 2002
    9
    Okay , So I guess I'm going with the Shiva . It will be a few more weeks until I order . I can't wait !
    Thanks fellas !
  5. Travis G
    Jan 6, 2002
    94
    You have chosen...
    Wisely[​IMG]
