first DIY question
Discussion in 'Home Theater Projects' started by kyle-sm, Dec 7, 2003.
  1. kyle-sm
    kyle-sm Agent
    Oct 9, 2003
    42
    I want to build 2 bookshelf speakers just for fun, and to gain a little experience in doing it. I've already done a bit of wood working to make myself shelves, furniture, boxes........ and have access to a huge shop. What is the best I can do for about $100 in hardware/wood/baffles.
    Also an unrelated question. Why does everyone use mdf? Why not use a real wood such as walnut or cherry? And also if you did use a real wood would there be any reason not to use dove tail joints?? These joints are stronger than screws so could this possibly be an advantage??
    Kyle
  2. perry web
    perry web Stunt Coordinator
    Dec 6, 2003
    64
    I am very new to DIY speakers but I do a lot of woodworking so I might be able to answer your MDF question. MDF is very stable (does not expand as much w/ temp and humidity changes) and the thickness is constant so it is easy to work with but the main reason, I believe, is that MDF is very dense or "dead". You do not get reverberations in the wood. I have read where people have used a nice beech plywood but it would be cheaper to make your box out MDF then veneer the box. IF you wanted rounded corners you can use 1/4 oak or maple plywood and cut it small and fit in 1/4 round molding in the corners. this would a nice finished look.
  3. Hank Frankenberg
    Hank Frankenberg Cinematographer
    Oct 13, 1998
    2,573
    Yes, it's because of MDF's density/lower resonance that it's better acoustically for full-range speakers. It's a nice serendipity that it's also very inexpensive.
  4. kyle-sm
    kyle-sm Agent
    Oct 9, 2003
    42
    no one has thoughts as good options for around $100??
  5. RoyceDB
    RoyceDB Extra
    Dec 10, 2003
    17
    when I build mine, I want to cover it in either aluminum or stainless, because I have a "silver" theme in the room. BTW, what is MDF? I am very familiar with woodworking and all, just wondering what that means[​IMG]
  6. Allen Ross
    Allen Ross Supporting Actor
    Sep 30, 2002
    819
    mid density fiber, you can also use 13ply baltic birch, it more expensive then MDF by far but you don't have to veneer, so BB is actually cheap and saves a ton of time IMO.
  7. Joe Ku
    Joe Ku Stunt Coordinator
    Apr 1, 2003
    69
    These are supposed to sound pretty good and you should be able to complete them for under $100
    http://www.speakerbuilder.net/web_fi...ts/DBP/dbp.htm
    Another option would be the Audax Home Theater surround monitors. Parts express has the woofers and tweeters for these on sale. should bring the total down to around $100. I own these (I use them as surrounds) they sound very good but will require a sub for the low notes.
    You could also try these
    http://www.wadsnet.com/~dtenney/dayton_8MT.htm
    You could build these ported also to extend the low end.
    Good Luck
