Steve Carlo
- May 6, 2003
Hi,
My local cable company (Cablevision) provides HD cable boxes. They have the following outputs:
Firewire
USB
HDMI/DVI
Component
co-ax (STD def)
My Mitsubishi WS555-11 has the following inputs which I could use:
Firewire
Component
some DTV inputs (not too sure what the difference here is)
I am trying to decide whether I should go with the Firewire or Component inputs for 1080i HD signal from the box.
Any thoughts of if there is any difference at all?
Thanks!
Firewire
USB
HDMI/DVI
Component
co-ax (STD def)
Firewire
Component
Thanks!
