finishing my rack, legs/posts for the rack, the whole 9 yards
Discussion in 'Home Theater Projects' started by jasonBarczew, May 21, 2005.
  1. jasonBarczew
    jasonBarczew Auditioning
    May 2, 2005
    10
    I'm building a sub enclosure, audio rack and tv stand. I might do the rack/stand together. I have a 32 sony Wega around 125 lbs. I'm researching the different DIY posts to find the right one for me (so if you have any flei rack, tv stand designs, I would appreciate an email or link.
    I'm leaning towards veneer sheet finishing but am looking for the best options. I'm using MDF for the construction. Where can I find this veneer at? Can it be found locally at a Home depot so I can get it right away or do I have to get it online?
    My room is dark red maroon so I'm looking at walnut or cherry finish ( a darker wood color)
    I'm also looking at other ideas for 5/8 bolts to give it a more polished look, any ideas? I saw someone covered his bolts with PVC, what do you think?
    thanks
  2. Todd Nichols
    Todd Nichols Auditioning
    May 11, 2003
    10
    Home depot will only have oak veneer. Try oakwoodveneer.com, or ebay which is what I typically do. Good luck.
  3. Mattak
    Mattak Stunt Coordinator
    Dec 15, 2003
    247
    The two HD's in my area have NO veneer. I picked up quite a bit on ebay for cheap. Check out the seller woodforu
