Andrew Lin
Grip
- Mar 7, 2002
So today I finished up glueing together my AV1 enclosures with the Black Hole material and Cross overs in place inside. I was anxious to try them out so I put in the drivers and connected them all together and put them against my current HT speakers the Polk Audio RT35i's.
Listening to them both with some trumpet concertos as well as some Dave Matthews, my feelings are kind of mixed. First it seems that the impedence of the AV1s are some what higher than the Polks, that is I have to turn up the volume higher on the reciever in order to get the same volumne output from the speakers.
That aside, it seems that the AV1s seem very smooth, however it seems to lose accuracy in that respect. The RT35is thus seem brighter and more accurate. When listening to this, it shocked me as the AV1s are suppose to out perform the RT35i's with out breaking a sweat.
So this leads me to think...did I do something wrong in constructing the speakers? I followed the instructions using 3/4" MDF tuning the box to 55hz (I believe, I'm to lazy to go down and check the specs from GR) I put in the Black Hole material on the two sides as well as the top of the inside of the enclosure. The cross overs were built correctly, I'm fairly confident in my soldering job.
Do these speakers need time to be broken in? Does this description sound correct for these speakers? Am I just crazy and I have no idea what to listen for in a good speaker? (
