Find an AMp for my Maggie
Discussion in 'Archived Threads 2001-2004' started by Martin Jiang, Feb 9, 2003.
  1. Martin Jiang
    Martin Jiang Agent
    Jul 13, 2000
    31
    I just got a pair of Maggie SMGa and can not believe my ears, when playing Diana Krall there is no comparison! However, I do think it needs more power. I am currently using a HK signature 2.1 which only has 100Wpc. And I am looking for a powerful amp that has 200wpc or more. I got my eyes on the carver tfm35X, is that a good choice for the SMG? or do you have any other choice around the same price?
  2. DanielM
    DanielM Stunt Coordinator
    Jul 5, 2002
    224
    how about a bryston 4b-st
  3. Yogi
    Yogi Screenwriter
    Jul 25, 2002
    1,741
    I would choose a warmer amp to go with Maggies. Something like a Rotel, Parasound or a B&K in the 200W/ch range.
  4. Alex Dydula
    Alex Dydula Stunt Coordinator
    Nov 1, 2002
    170
    I have a PS Audio 200C (200watts per channel)I used to drive my 180lb Mirage M1's that would do an awesome job....its for sale if your interested...(a $1800 piece of gear for $400, you pay shipping).
    Alex
  5. PhillipC
    PhillipC Stunt Coordinator
    Apr 6, 2002
    100
    The Bryston 4B-SST would fit your needs nicely. Better than the 4B-ST
  6. Lewis Besze
    Lewis Besze Producer
    Jul 28, 1999
    3,134
    Is the HK rated 100wpc into 4 ohm?
    If not you can add 50% minimum to that rating in 4ohm compare to 8.
    Maybe it's more current you after,not sheer wattage?
  7. Yogi
    Yogi Screenwriter
    Jul 25, 2002
    1,741
    You are right they are neutral to forward for my tastes, and I like my sound warm. Hence the statement.
    Hope that makes it clear.
  8. Lewis Besze
    Jul 28, 1999
    3,134
    Gotcha.
  9. EarlR
    EarlR Stunt Coordinator
    May 13, 2001
    71
    Martin,
    I would recommend trying to find a used Classe 200 or 201. This amp would handle the Maggie’s fine and sound great.
    Earl
  10. John A. Casler
    John A. Casler Second Unit
    Apr 29, 1999
    475
    What is your budget?
