Finally up and running on XP
Discussion in 'Archived Threads 2001-2004' started by Chris Bardon, Jul 29, 2002.
  1. Chris Bardon
    Chris Bardon Cinematographer
    Jul 4, 2000
    2,059
    Finally have XP up and running, and aside from the nightmare OS install from hell that I never want to have to deal with again-it's great.
    Had a little problem with the XP disc having a corrupted file on it. Do a search for "controls.man" and you'll find more than a few people bitching about this one. Installed 2000 just so I could burn another XP disc that worked, but ended up not booting. Had to boot from the bad disc and switch to the good one halfway through.
    The good: Built in DSL support, and automatic installation of network printers are just a couple of nice surprises. Plus all of the features that I know and love from NT are on a games-capable machine (like process-level control). Also, they finally seem to have made it simple to migrate data from Outlook express (you could do it before, but it was never pretty).
    The Bad: Too much autoplay-I've managed to turn it off for everything but application discs-any way to get rid of this? I don't need windows telling me when I put a CD in the drive-I know I did dammit! Also, changing "minimize all" to "show desktop" is still bugging me, and the "find files" command isn't accessible by KB only anymore-you have to click through the "search companion". Just a little thing, but I used that a LOT.
    The Ugly: The windows XP "new look". Took a little fiddling, but I set everything back to the way I like it. Glad that they let you stick with the "classic" UI-the new one just seems to waste too much space for my tastes.
  2. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    [​IMG]
    I had an interesting time upgrading to XP as well from ME. It took about 2 weeks to get everything the way I wanted it. Had to download a couple of drivers as well on top of that for a couple of devices. The upgrade certainly was not as smooth as I would have liked although I am happy with the final result. It has some great features that I like. Although it has the snapshop feature to restore your system into the past (which actually works when I tried it), nothing beats having an actual backup of your whole system which I have also done on a second HDD.
  3. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
    I installed XP on a fresh new computer, it was a very comfortable process... After some tweaking, it works great. I run Diskeeper defragmenter daily, and its running very nicely... no huge nagging errors/crashes, its awesome...
    Go out and find yourself some cool themes/bootscreens/login screens, personalize it! [​IMG] (check out themexp.org to start off)
  4. Masood Ali
    Masood Ali Supporting Actor
    Jan 31, 2002
    921
    I never upgrade OS's; always a clean install. Especially when the old and new OS use different file systems (ME with FAT32 and XP with NTFS).
  5. John*Jones
    John*Jones Stunt Coordinator
    Jun 4, 2002
    189
    Here's a another way to disable autoplay altogether.
    You can disable autoplay by running the Group Policy Editor (gpedit.msc) and selecting Administrative Templates > System >Turn Off Autoplay. (To run the Group Policy Editor, type "gpedit.msc" in the Start menu's "Run..." box.) Another way to control autoplay is to right-click the CD's icon in Explorer, then select the Autoplay tab under "Properties".
    If this isn't what you were looking for, I apologize. I know how annoying autoplay is...if all else fails you can always hold down the shift key when you insert the disc to prevent autoplay. [​IMG]
