The long awaited TiVo HD Series 3 is now available:
http://www.tivo.com/cms_static/press_111.html
Dual-tuner: any combo of NTSC, ATSC, analog cable or digital cable (via CableCard). Outputs to HDMI, component, S-Video or composite. Very flexible video output settings. Built-in wired ethernet, and 2 USB ports (for wireless LAN). eSata port for external storage expanison. Reworked backlit remote. Front-panel display tells you what shows are recording, and what the output resolution is.
Negative: $799 is pricy. eSATA port is not yet enabled (a software update later this year will fix that). No Multi-Room Viewing or TivoToGo right now, due to restrictions imposed by CableLabs certification (TiVo wants to turn these on in the future if their negotiations with CableLabs will let them).
Reviews up from PC Magazine and Engadget.
Mine is on order!
Mine is on order!
