Carlo_M
- Oct 31, 1997
Okay, I was going to resurrect the old thread, but I have a question that I thought might get overlooked if I put it in that rather lengthy thread.
1. Why on AVIA low grey patterns (like 20 or 30 IRE) would my TV give something that looks like snow or static? It doesn't do it for blacks, and higher greys, just at the low IRE ones.
- Could this be SVM? I don't know what it looks like so I don't know...
- Could it be the Monster Video 3 Component cables I bought?
- Could it be the Sony S560D player?
- Could it be the AVIA disc test pattern?
- Is it a faulty TV?
I don't notice it much, but on rare occasion on a dark scene, if it matches that tone of grey, I can see a little bit of the snow/static, like lighter grey static streaks over the darker grey. You know, like the ones you get when cable reception is not so good?
Other than this annoyance, I'll post my comments on the set a little later (they are mostly positive). Just wanted to throw this question out there.
Also, has anyone figured out how to disable SVM on this set yet?
See you all soon, I gotta run and buy The Gift and Family Man.
My dealer of choice:www.yawaonline.com
[Edited last by Carlo Medina on July 17, 2001 at 06:39 PM]
