Hi everyone,
I had a couple of other threads when I had the Pioneer AJ 5.1 System and was recommended to go with this system.
It consists of the RBH/Emptek R55ti Tower Speakers, their big Channel speaker, and bookshelf speakers. I also ordered the PB 1000 from SVS.
First off, I want to say that the Speakers sound fantastic, I just really need to know what settings I need to have on and what can be improved on.
The main issue so far is the Sub. I took the advice from another member and set the gain to 12'oclock, the crossover all the way to the right, and kept the degree setting at 0.
Then I used Audyssey to configure it and viewed the result. The final result was -.5 decibels. He mentioned it just need to be within the 0 to -8 decibels so this falls into that. So I left the subwoofer alone and went into the manual settings inside Audyssey and bumped it up to +4db on the receiver. Is this correct?
I have to crank the volume of the receiver up to -9db to start hearing the sub and it sounds really weak compared to the little 8" AJ sub, the 8" DT cube 2000, and 12" klipsch. I think there is a setting off because this was supposed to be a better sub than all of the above and it is front firing, which is better for my apartment.
So we watched Batman Begins last night which I had to manually select Dolby True HD (5.1 DD was the default).
We had the receiver cranked up to -9db and the sound was great out of the speakers, but not much was coming out of the subwoofer. We also adjusted the "dialogue level" up to like 8 or 9 db so we could hear the words as clearly as possible.
Should you have to listen to a movie at -9db to really feel the system working? I thought we could keep it at much less and really feel it, but if it has to be up this loud, that's fine too. I'm sure the speakers can handle it.. I just do not know much about these surround sound systems since I've always owned Soundbars.
Keep in mind, I live in a 700 square feet apartment on the second floor so it is not a big place by any means.
Is there any other settings I need to check as well? I saw there is something called Dynamic Volume and a lot of other settings in Audyssey.
The receiver is the 2015 X-1200w which is a 7.2 channel receiver with Audyssey Silver.
Thanks of any feedback!
