Finally got a SPL...how do I use this thing?
Discussion in 'Archived Threads 2001-2004' started by Scott Simonian, Apr 13, 2002.
  1. Scott Simonian
    Scott Simonian Screenwriter
    Jun 20, 2001
    1,281
    Actually, I know how to use it, I just dont know if I know how to use it correctly.
    I just got it today. Ive been playing with it around the house. I know how to read the SPL reading, setting it to the correct SPL the the knob and all. The "A&C weighting" doesnt make a whole lot of sense but I know which to use. I get teh slow and fast response. I got that down quick.
    I just dont know how to use it in the HT. What am I supposed to use for calibration? I dont have VE or Avia. I dont feel like going back to the store to get one of them either. The only thing I have is the movies with "Optimode" and I was under the impression that it was no good.
    For what, I dont know. All I really want to check is the bass response in my room at the listening area. Whats the quick fix?
    Oh yeah, I have a tone generator on my computer. I could burn a few tracks on a CD, but my DVD player and Xbox dont like CDRs or CD-RWs. UGH!
    Woops, I also think Im going to need the RatShack SPL meter correction numbers. I dont know about the digital, if it needs correction. Who cares about teh digital meter anyway, I got the analog meter. [​IMG]
  2. Bill_Weinreich
    Bill_Weinreich Second Unit
    Sep 25, 2000
    317
    Scott,
    You're well on your way. You know the range settings and the slow setting (used for averaging levels rather than peak) but about the weighting. Set it to C. That gives a frequency range 32hz-10khz(A weighting is about 500hz-10khz). Without a test disc, you can use the internal tones of the receiver. The advantage of the test disc is that you are getting the levels from the DVD(all wiring and processing included). The best way to use it is on a tripod at the main listening position. Point it forwards and angle it up to about where the front wall meets the ceiling, grab your remotes and get started.
    P.S. the analog works great no need for the digital
    Bill
  3. Scott Simonian
    Jun 20, 2001
    1,281
    Yeah, digital sucks. :p)
    I went ahead and put a tone generator on my dads PC tablet. I got my SPL from my room. I wanted to know how it was at the seating location so I left (most of) the things in the HT at normal. I wanted something realistic and common. I did the testing at a little on my personal volume.
    I got the RadioShack meter correction off the web. There are some gaps in it though. Do I just put the corrections where it is listed? Or do I guesstimate the parts between the frequencies.
    For example, 10hz > +20db, 12.5hz > 16.5db, etc.
    I wish I knew how to use Excel better. Im not sure how to make the right graph for such a thing. Whats the quickest way to make a graph for SPL measurements on Excel?
  4. Scott Simonian
    Jun 20, 2001
    1,281
    Hmmm...
    Maybe if I put up my awful measurements, someone would lend me a hand. I gotta fix this.
    Here they are, corrected.
    100hz - 96.5db
    90hz - 86db
    85hz - 93.5db
    80hz - 99.5db
    75hz - 97db
    70hz - 98.5db
    65hz - 98.5db
    60hz - 95db
    55hz - 95db
    50hz - 91db
    45hz - 91.5db
    40hz - 101db
    35hz - 96db
    30hz - 94.5db
    25hz - 91db
    20hz - 91.5db
    18hz - 76db
    15hz - 72db
    10hz - 71db
    Now, not all those frequencies were stated on the form of corrections that I have. So, I only put corrections on the frequencies that stated for correction. The others were left as recorded.
  5. brucek
    brucek Second Unit
    Dec 29, 1998
    335
    Scott,
    Generally, when measuring low frequency response, most people measure from 16Hz to 160Hz at 1/6 octaves, at about a level of 85dB to 90dB SPL taken with a Radio Shack SPL meter at your normal prime listening position. For a source, use a CD playing 3 to 5 second sine wave tones..
    Take measurements using the sub only and your processor with normally used crossover frequency.
    The correction constants for the Radio Shack meter for 1/6 octaves are valid for sine waves and are:
    16Hz +11.5
    18Hz +8.0
    20Hz +7.5
    22Hz +6.5
    25Hz +5.0
    28Hz +4.0
    31.5Hz +3.0
    36Hz +2.5
    40Hz +2.5
    45Hz +2.0
    50Hz +1.5
    56Hz +1.5
    63Hz +1.5
    71Hz +1.5
    80Hz +1.5
    89Hz +1.5
    100Hz +2.0
    111Hz +1.0
    125Hz +0.5
    142.5Hz +0.5
    160Hz -0.5
    It's a good idea to use the information and Excel graphing tool on Sonnie Parkers site (listed below) which has the graphs all pre-done including compensation correction for the SPL meter.
    Read all the information on this site including the links. The site is dedicated to equalization with a BFD. Even though you don't have an equalizer, the information is still very valid.
    http://www.snapbug.ws/bfd.htm
    Limit your testing to sixth octave tones. The Excel tool on Sonnie's site is set up for this.
    brucek
  6. Bill Kane
    Bill Kane Screenwriter
    Feb 5, 2001
    1,359
    brucek, counting your scale above, I have seen 3 RS conversion corrections. THE MOST COMMON:
    20hZ-+6.2dB
    25hZ-+4.4
    31hZ-+3.0
    40hZ-+2.0
    50hZ-+1.3
    63hZ-+0.8
    80hZ-+0.5
    Yours has much higher values added.
    I wonder if there are difference among SINE WAVE TONES, PINK NOISE Tones and/or Receiver-Generated Tones?
  7. Scott Simonian
    Jun 20, 2001
    1,281
    Ah great, that web page was exactly what I was looking for.
    Thanx
    So do we have the real corrections somewhere?
  8. brucek
    brucek Second Unit
    Dec 29, 1998
    335
    Bill,
    The constants I listed are the accepted values from many trusted sources, including SVS where you'll find 1/3 octaves.
    http://www.svsubwoofers.com/faq_rscomp.htm
    These are correction constants to simply compensate for inaccuracies in the meter.
    brucek
  9. Scott Simonian
    Jun 20, 2001
    1,281
    Bruce,
    On the SVS site, it gives correction values that are not the same as you have just stated earlier. Where did you get those? The correction chart that I have is the same as the one on the SVS site. My list goes throughout the whole audible range, though.
  10. Scott Simonian
    Jun 20, 2001
    1,281
    Excuse me, I miss read your post. Your correction values are right.
