Final verdict on component switch
Discussion in 'Archived Threads 2001-2004' started by ethan_l, Oct 25, 2002.
  1. ethan_l
    ethan_l Stunt Coordinator
    Oct 25, 2002
    72
    I've read through several of the threads on this topic
    to me seem it's pretty much come down to
    JVC JX-S11 vs the Inday switch
    is there a review on the Inday?
    seems like both are passive switches but the Inday claims
    to have a much higher bandwidth at 230Mhz
    Thanks for any tips
  2. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
    Could you tell us what kind of theater you have? Chances are if you won't be passing 720p or 1080i signals through the switchers you won't be able to tell the difference.
  3. Dave E H
    Dave E H Supporting Actor
    Apr 23, 2002
    829
    I've got the JVC and it works great. From what I've read, it shouldn't make a difference in my setup which on I have (there's a link to a great video bandwidth site somewhere that it explains this in depth.) Net net - I don't think it was going to be an issue.
  4. Adrian_S
    Adrian_S Second Unit
    Apr 29, 2002
    311
    Some one else posted this, but here are the details and the link: Link
    HDTV 4x1 Component Video Switcher
    General Features
    HDTV Analog (Y,PbPr or RGB) 4-Input to 1-Output Switcher.
    Accepts any analog component video type, progressive or interlaced at any scan rate.
    Combine HDTV Receiver's and Progressive Scan DVD Players into ONE Monitor Input
    Remote Controllable!
    Small Size, 2x6x4". All Connectors are Gold Plated RCA.
    Very Wideband. Greater then 230MHz.
    Model: RGB4X $168
    Use your remote control to train the switcher to cycle through the inputs with ONE button.
    Perfect for simple systems that may only require manual or simple remote selection.
    Model: RGB4X-R $187
    Comes with a 4-Button remote control to directly select the inputs.
    Ideal for sophisticated systems that require Discrete IR Codes to switch to a particular input.
    Download Philips Pronto Configuration File for the RGB4X-R. RGB4X-R.CCF (TSU2000)
    I'm getting this one for my setup... not to bad in price.
  5. Adrian_S
    Apr 29, 2002
    311
    You can pre-order the Linx Wireless Xbox Controller for 59.99...
    Ebgames Link
    - Adrian
  6. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
    Adrian- wrong thread?
  7. ethan_l
    Oct 25, 2002
    72
    well I was just wondering if it's really true
    that the Inday can really support high bandwidth
    currently I only have 480p/1080i support on my HD
    but I might upgrade to plasma later on which will support
    720p
