Final decision time - Input needed
Discussion in 'Archived Threads 2001-2004' started by Travis Cain, Mar 2, 2003.
  1. Travis Cain
    Travis Cain Stunt Coordinator
    Jan 25, 2003
    79
    OK guys, I am planning to begin construction tomorrow (Monday) evening on my sub and there is still a detail or two I could use some input on.. This is what is certain.
    Amp - 360 watt plate amp w/ remote from MCM electronics.. I was only going to get a 250 from PE but MCM had a deal on this one for $135 which has already went back up to $189..
    Driver - Tempest w/ 2 PR-15's
    I had originally planned to build a sonosub but changed my mind and am going with a box since I prefer PR's.
    Now, the part I am having trouble deciding is whether to go with an adire alignment or a EBS alignment. I had originally planned to go with an EBS, but my main concern is driver over-excursion with that much power since the consensus is that 250W is about the max for an EBS alignment. Would an adire alignment allow a little more power handling before reaching x-max? If it's about the same either way, I'll just go with EBS.. Nothing wrong with a little amplifier headroom..
    Also, with either alignment, I will be modifying it slightly to make it front firing with the pr's on the sides, all centered, while trying to maintain the proper enclosure size.
    P.S. I know many of you will want to tell me to use a ported design instead since there is enough room in a box that size, etc etc etc etc etc etc etc etc etc, but don't bother. I like PR's and that is that. [​IMG]
    Thanks in advance for your input, guys...
  2. Travis Cain
    Jan 25, 2003
    79
    Sheesh... 41 views and not one piece of input?
    I feel left out..
  3. Heard a pair of tempests that I liked and they were adire alignments. Havent heard the EBS, but the Adire sounded really good.
  4. Jeff Rosz
    Jeff Rosz Second Unit
    Sep 24, 2000
    335
    one good thing about PR's is, you can add or remove mass for a re-tune.
    the bad part is there is a big difference in the box sizes between the two alignments.
  5. Owen Bartley
    Owen Bartley Second Unit
    Nov 11, 2002
    487
    Sorry, I don't know much about PR's and I kind of custom did an enclosure size to fit my room. If it helps at all, its a 210L ported box and it sounds great.
  6. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
  7. Travis Cain
    Jan 25, 2003
    79
    Thanks for the input, guys. I got the answers I needed from Dan in person today, so this thread can die.. [​IMG]
  8. Jeff Rosz
    Sep 24, 2000
    335
    thomas,
    i thought they were talking about a super special mondo file only gotten by asking for it. anyway good luck with it travis.
