Final decision. Advice needed.
Discussion in 'Displays' started by Roveen_A, Dec 20, 2003.
  1. Roveen_A
    Roveen_A Auditioning
    Dec 19, 2003
    10
    Thanks for all your help and the advice you've all f=gicen to this newbie.
    I think I made up my mind on what to do. Let me know if you would agree.
    Room dimensions: 14.5' x 11.5' x 8 '
    Room has no windows and is lighted by 4 sconce, 4 recessed dimmers. Otherwise, I can make it completely pictch dark.
    I will use the Sony Dream surround system that I have for this small room.
    I have now decided to purchase a projector (instead of the use the Epson 730c my company gave me). I really want the 16:9 widescreen format and this is not the case on the Epson. Plus, I probably will have to take the projector on/off the mount in case I need it for work. That can be a hassle, right?
    1) My question is: If the projector I buy(hanging from ceiling) is 11 feet away from the screen, what projector do you recommend I purchase that is sub $2000 or even sub $1500? I want good brightness and resolution in 16:9 aspect.I also want a projector that can accept: DVD video, cable TV, Playstation 2. If it can do computer too, that would be ok. Are all this standard now on all projectors?
    2) I want to buy a Da Lite screen. From the 11 feet distance, what screen size and model would you recommend? I was thinking the 96" diagonal would be good. Is that too BIG?
    I think basically I am looking for the right projector/screen combination taking into consideration the room dimensions.
    I can use all the advice I can get. Thanks for making this a relaity for me.
  2. DavidVT
    DavidVT Stunt Coordinator
    May 7, 2003
    182
    Thinking of the Sanyo PLV-Z1/Z2 or Panny L300 or X1
    For any of the above, you should look into a DIY screen which can be made to your exact dimensions and for less than 100 bux.
  3. Cees Alons
    Cees Alons Moderator
    Jul 31, 1997
    19,412
    312
    9,110
    Cees Alons
    Roveen,
    I move this thread to the Display Devices (TVs/Projectors) forum. I expect you to get even more response there!
    Cees
