Filling in the gap
Discussion in 'Home Theater Projects' started by Benihana, Dec 16, 2003.
  1. Benihana
    Benihana Stunt Coordinator
    Nov 14, 2003
    190
    What happens when you are building a box, and one of the sides is like 1/8" short, what can i use to fill in this gap?? Should i get a real thin piece of wood and glue it between both sides? .Thanks.
  2. Jamie=B
    Jamie=B Auditioning
    Sep 27, 2003
    12
    On car boxes we use fiberglass to form a box Iam sure it will patch one of you fill the thickness of the gap. Make it a smooth as possible than bondo it for a smooth finish..
  3. Dave Poehlman
    Dave Poehlman Producer
    Mar 8, 2000
    3,813
    I'd probably caulk the inside well and, when that's dry, fill in the gap with wood filler or bondo and sand smooth.
  4. Benihana
    Nov 14, 2003
    190
    anybody know how much wood filler is?? Thanks.
  5. DaveKahler
    DaveKahler Stunt Coordinator
    Nov 23, 2002
    73
    couple bucks
  6. Jeff Meininger
    Jeff Meininger Second Unit
    Jun 5, 2002
    481
    Bondo is better than wood filler, I've found. Wood filler is easier to apply, easier to sand, and smells a whole lot better than bondo, but it also doesn't adhere as well and seems to be more brittle than bondo.
    Either one will probably work, but a small can of bondo is worth the extra few bucks IMHO.
  7. TimForman
    TimForman Supporting Actor
    Dec 4, 2002
    847
    Bondo. Wood filler is not going to handle something that large very well.
  8. Wayne Ernst
    Wayne Ernst Cinematographer
    Feb 24, 2002
    2,588
    From the inside, you could fill the gap with a tube of Liquid Nails. This stuff is under $2.00 for a tube that will fit into a caulking gun. It will make a very good seal for that 1/8" crack. However, filling the outer part of the crack might be a bit tough. You could try shooting some of the Liquid Nails adhesive into the crack and sand it after 24 hours or so (after the adhesive has dried.)
