Steve Young
- Feb 16, 1999
- Steve Young
I have been working on getting the ground loop hum out of my system for a couple of years now. It all started when I put my first amp (with a 3 prong plug) into my system. I then added a second amp (also with the 3 prong plug) for my subs. I then bought a Panamax MAX5100 hoping to fix my problem. In my system I have 2 satellite dishes so I could only run the antenna for one of them through the Panamax, because the other coax connection is for CATV. The only way I could get rid of the hum was to use cheater connectors on the amp cords, which isn't a good idea, seeing that I am an electrician and know the dangers of this. Well I did a test just the other day by hooking everything up normally and the hum was still there, which I expected. I removed the antenna connection going to the IRD that isn't connected through the Panamax and the hum disappears completely. Now what I am thinking is that all I need is another isolator for the other dish antenna cable. Does anyone know if there is such a thing for isolating a DBS cable on it's own, or do I have to buy another surge protector with the DBS protection built into it?
Sorry to ramble on.
Thanks for any help.
Steve
Sorry to ramble on.
Steve
