Brian E
- Aug 12, 2000
Thanks to people here I've got my new equipment coming. My next question is what else will I need to have/do when it gets here?
I'll be getting an SPL Meter and calibration disc.
I have some Monster Cables from my current setup and I'm thinking about using Acoustic Research cables for the rest. Are these ok? Coax or Optical audio hookup for my DVD player (Panasonic A310)?, the player has both. What should I look for in a cable for the sub?
Anything else I should know or do when setting it up?
The rears I'll be using for now are from my old system (Aiwa SX-NAV900 150W 6ohm 3-way). These speakers have small wires hardwired into them. To extend these wires do you suggest splicing into the wire that's there or opening the speaker and soldering all new wire to it?
As always thanks for your input. My new equipment along with it's specs is listed below.
Pioneer VSX-709S
Processing:
Dolby Digital & DTS Decoding
24-bit DSP
5 Channel Stereo
Multi-Channel Tone Controls
5.1 Acoustical Environment DSP
5.1 Advanced Theater
Midnight Mode
Multi-Channel Digital NR
24-bit A/D Converters
6 Channels 96k / 24-bit D/A
Power:
Direct Energy MOSFET Amplifier Design
Direct Current Construction
Double Density Amplifier PCB
Stereo: 100 Watts per Channel (1 kHz, @ 8 ohm, 0.09% THD)
Surround: 100W x 5 (1 kHz, .09% THD)
Convenience Features:
5.1 Channel Input
Dot Matrix Display
Video Signal Select
Smart
Pre-Amp Output (ALL)
4 Assignable Digital Inputs & 1 Out
4 Audio & 5 Video Inputs
S-Video Switching Banana Speaker Terminals (ALL)
Front A/V Input w/S-Video In
Direct Switch
3 step FL Dimmer
2 Rear Panel AC Accessory Outlets
B&W LCR60 S3 Center Channel
Description 2½-way vented-box system with magnetic shielding
Frequency Response 70Hz - 22kHz ± 3dB on reference axis
Frequency Range -6dB at 55Hz and 42kHz
Sensitivity 88dB spl (2.83V 1m)
Nominal Impedance 8 ohms (minimum 3 ohms)
Power Handling 25W - 120W into 8 ohms on unclipped programme
Drive Units 1x 25mm (1in) metal dome high-frequency
1x 130mm (5½-in) woven Kevlar® cone bass/midrange
Dispersion Within 2dB of response on reference axis
Horizontal: over 20° arc
Vertical: over 40° arc
(Units horizontally in line)
Harmonic distortion 2nd & 3rd harmonics
less than 1% 70Hz - 20kHz (90dB spl, 1m)
Max. recommended cable impedance 0.1 ohms
Crossover frequencies 400Hz, 4kHz
B&W DM600 S3 Fronts
Description 2-way vented-box system
Frequency Response 75Hz - 22kHz ± 3dB on reference axis
Nominal Impedance 8 ohms (minimum 3.0 ohms)
Power Handling 25W - 100W into 8 ohms on unclipped programme
1x 130mm (5.0in) woven Kevlar® cone bass/midrange
Dispersion Within 2dB of response on reference axis, Horizontal: over 40° arc, Vertical: over 10° arc
Harmonic distortion 2nd & 3rd harmonics less than 1% 88Hz - 20kHz (90dB spl, 1m)
Crossover frequency 4kHz
CSW BassCube 15
Woofer Size 15"
Amplifier Power 150 Watts
Frequency Response 28 - 170HZ
Variable Crossover 28 - 160HZ
Level Control
Phase Switch
Line-Level Input
Weight 73 LBS
Pioneer VSX-709S
Processing:
24-bit DSP
5 Channel Stereo
Midnight Mode
Power:
5.1 Channel Input
Dot Matrix Display
Video Signal Select
Smart
Direct Switch
3 step FL Dimmer
B&W DM600 S3 Fronts
CSW BassCube 15
Woofer Size 15"
Level Control
Phase Switch
Line-Level Input
Weight 73 LBS
