Fidek 600w SVS amp
Discussion in 'Archived Threads 2001-2004' started by JasonWaddington, Aug 11, 2002.
  1. JasonWaddington
    JasonWaddington Stunt Coordinator
    Aug 7, 2002
    120
    Exactly how loud are those FANS?
  2. SVS-Ron
    SVS-Ron Screenwriter
    Jun 2, 2001
    1,074
    Jason,
    Some folks might be confused about what you're asking. Are you looking into the old Fidek amps we used to sell? Or the current Samson line (it's been over a year we've carried the Samson instead of the Fidek).
    If you ARE asking about the Fideks, I'd put them at about the same level of noise as a typical PC power supply fan. The Samsons are much much quieter. Barely a wisper in a dead quiet room from a couple feet away. With music or movies playing totally inaudible in my opinion.
    The Fidek was a good amp (still is if you can find one used) but the Samsons are better in every way. Regarding fan noise there was no comparison and became one of the primary reasons we switched.
    Hope this helps some. I'm sure others will have opinions on the matter.
    Ron
