Feedbak though speakers
Discussion in 'Speakers' started by Bob_Lawrance, Oct 21, 2003.
  1. Bob_Lawrance
    Bob_Lawrance Stunt Coordinator
    Apr 14, 2002
    163
    I was wondering if anyone knew why sometimes when I turn on and off my rec and amp, I sometimes her a sound from speakers, it is almost like a 'pop'.
  2. Tim Streagle
    Tim Streagle Stunt Coordinator
    Sep 1, 2003
    65
    Be sure to power off the amplifier first and this should help. An amplifier is the last component in the chain before the speakers. Shutting it off first mutes the remaining components. If you still have a noise, it may indicate a problem with the amp circuitry. Have it checked.
  3. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    I believe it is the caps in the amp making the noise as they dump some charge, and is normal. I don't think there is anything you can do about it. Powering off the amp first probably won't make a difference.
