Doug Montgomery
Grip
- Nov 18, 2003
O.k fellow DIYer's
After much posting and reading (as much as I can on 19200 dialup here in Hawaii)...I have decided to make a Sonotube sub with four Stryke AV15 MKII (thanks John Janowitz). I choose them cause of price and there simulated responses vs other drivers. I considered the Dayton Titanic MKII (only available in 12' though), but the cone excursion was pretty bad at lower freq.
Specs are as follows (wish I could attach files)
You'll notice I tuned the cylinder a little low (17 hz), but I found it helps shift the GD, VV and CD lower.
The Isobaric design really seems to help me keep the size down and it should make the drivers respond very quickly. Size is imporrtant, as if I were to use only 1 or two drivers, the tube would have to be hughe for the same response. (WAF :0 )
Amplifier is a ADCOM GFA555. Question, any difference in driving the four speakers in bridge mode vs runnin two drivers off one channel and the other two off the other channel?
Any suggestions or comments welcomed
Doug
Code:
Box Properties
--Description--
Name: SiloSub Quad-15 Ver 1
Type: Vented Box
Shape: Cylinder
Dimensions: 32" High x 36" Wide
--Box Parameters--
Vb = 11.4 cu.ft
V(total) = 15.05 cu.ft
Fb = 17 Hz
QL = 6.703
F3 = 16.43 Hz
Fill = normal
--Vents--
No. of Vents = 1
Vent shape = round
Vent ends = two flared
Dv = 8 in
Lv = 34.2 in
Code:
Driver Properties
--Description--
Name: Stryke AV15 MKII
Type: Standard one-way driver
Company: Stryke Audio
Piston: Aluminum cone.
Suspension: Santoprene surround.
Frame: 12-spoke cast basket.
Voice Coil: 2-inch diameter.
--Configuration--
No. of Drivers = 4
Mounting = Compound (isobaric)
Wiring = Series-Parallel
Drivers sum coherently = Yes
--Mechanical Parameters--
Fs = 22.39 Hz
Qms = 5.293
Vas = 140.1 liters [140.1]
Cms = 0.143 mm/N [0.0358]
Mms = 353 g [1412]
Rms = 9.391 kg/s [37.56]
Xmax = 23 mm
Xmech = 30 mm
P-Dia = 325.2 mm [459.9]
Sd = 830 sq.cm [1660]
P-Vd = 1.91 liters [3.82]
--Electrical Parameters--
Qes = 0.517
Re = 2.95 ohms [2.95]
Le = 3.5 mH [3.5]
Z = 4 ohms [4]
BL = 16.84 Tm [33.67]
Pe = 500 watts [2000]
--Electromech. Parameters--
Qts = 0.471
no = 0.293 % [0.293]
1-W SPL = 88.5 dB [88.5]
2.83-V SPL = 91.15 dB [91.15]
Doug
