Feedback from AR owners? (1 Viewer)
Brian Kail
I am considering some AR speakers for HT use. Does anyone have any feedback about their product? How would I find a retailer in the SF/Bay area? Thanks.
Danny Tse
The last AR speakers I heard was the last series of Performance Series. I've seen the latest Performance Series at the Sears store in Oakland, but didn't hear them. As for the Hi-Res series, I believe LaserCity out of San Bruno/Brisbane carries them. Otherwise, check with AR at 1-800-969-2748. Personally, I like to check out the AR-15 and the AR-17 bookshelf speakers myself.
Brett DiMichele
Brett
Brian,
I own AR9 Hi Res Towers and an AR4C Hi Res Center and also
a pair of AR Performance Series Bookshelfs (216's) and another
Performance Series Center (C225) used as "back" surround.
The Performance series is "decent" for what they cost.. The
Hi-Res series in my Opinion are Giant Killers... The AR1
was review by Stereo Review to be a Class B Audio Product
and that's a goal that some speakers costing 5 times as much
or more, have not met..
The AR1,AR3,AR5 and AR9 all use the same basic design but
the lower the number the larger the sub woofer is. For example
the AR9 uses a 10" Sun where as the AR1 uses a 15" Sub. The
AR5 is the same as the AR9 only the AR5 adds it's own internal
amplification for the subwoofer secion, compliments of
Bob Carver Sunfire.
Check them out and I don't think you will be dissapointed.
NHCondon
