Chris:-/OV
- Sep 7, 2003
Hi Guys
I've managed to build up a fairly good theater even though i'm on a tight budget. It consists of a Denon AVR 3803, B&W DM 603 S3 (fronts), DM602 S3 (rears), LCR 600, Polk Audio PSW450 Sub all wired up with Monster bi-wire cable. Interconnects are Van den Hul The First Ultimate. I've spent every last penny on all of my equipment, upgraded, upgraded and upgraded!! But I'm still not happy. It's the room I'm in which is 6m(l) by 3m(w) by 2.3m(h) which is causing problems for me. The room is tiled and I have a large window situated behind my speakers (front). The walls are almost bare and there's only a couch in the room and carpets covering the tile and curtains for the window.
The problem is that when playing music especially rock, the frequencies are all mixed and muddled up and I can't differentiate between the different instruments. The same thing happens when watching movies. Also, the bass is very uneven in the room, in some places loud and in other places soft. I've tried everything, carpets on the window, foam on the wall, repositioning of speakers but now I'm fed up as nothing has improved the sound. This holiday though I am giving treatments to the room one more time before resigning my home theatre hobby. (thats how bad it is)
I've thought of building bass traps(one for each corner) and putting some sound absorbing panels on the walls. Do you guys have any other ideas which could remedy my problem?
Please, I'm counting on you guys to help me out.
Chris
Chris
