family "simple" mode
Discussion in 'Archived Threads 2001-2004' started by itai, Sep 5, 2002.
  1. itai
    itai Stunt Coordinator
    Jan 23, 2002
    221
    hi all
    how can i feed both the reciever and the tv with the signals from the dbs box?
    we need the tv to be used without the ht monster woken up each time...(guess who's phrase is that...)
    should i split the wires?
    [​IMG] thanks
  2. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    Does the DBS box have more than one audio output which you can use at the same time? If not, splitting should work fine (analog). If the DBS box is using a digital audio out, you probably can't go direct to the TV anyway.
    Does the TV have both audio input and ouput? If it does, you can use the audio output of the TV (which will almost certainly be analog stereo) to loop to the receiver and listen to whatever is on the TV at the time, providing sound is being fed to the TV. With the receiver off, you will still have sound on the TV.
  3. itai
    Jan 23, 2002
    221
    thanks john, it does have more outputs, [​IMG]
  4. Jesse Skeen
    Jesse Skeen Producer
    Apr 24, 1999
    4,495
    339
    4,110
    Way back when, my roommates wouldn't bother to turn on the amps when watching TV, so I finally stuck something in the earphone jack to turn off the built-in speaker, then broke it off so it stayed plugged in [​IMG]
