anthony.j
- Nov 28, 2006
- Anthony
I'm having our family room set up for a simple 5.1 system in a house thats being built right now. There's a fireplace in one side with the tv nitch above it.
I talked to my low voltage guy about laying out some speaker wires which can be done easily. Now the audio and video system will be in a rack beside the fireplace. Not knowing what TV and system I will be getting, I wanted to run a blank pipe which I could use later on to run some video and audio cables going to and from my TV. My or should I say our problem is we don't have enough wall space to run the blank pipe since its a very tight space such that if we push it, we could only put an inch pipe the most.
He suggested that we run now the most common audio and video cable for the tv, anything more than that would have to be on the side using cable management.
Now, I need suggestions on what are those most common or standard cables should I buy for him to put in?
