Familiar with Dayton 12" DVC, please help.
Discussion in 'Archived Threads 2001-2004' started by JimHal, Dec 5, 2001.
  1. JimHal
    JimHal Stunt Coordinator
    Aug 15, 1999
    87
    I recently ordered this driver and the 150W plate amp from Parts Express. I had the intentions of making a vented sub tuned to around 20hz in a 120L box.
    I downloaded Unibox and entered the specs for the 12" DVC.
    The program has recommended a closed enclosure with a volume around 86L with a Qtc of 6.
    A few questions:
    What do you guys think of these numbers?
    Would you recommend a closed before a vented sub?
    Is fill necessary? If so, how much?
    The max power input is 136W. Should I decrease the box size so the max power is increased to around
    150W (my amps max)? Would this better protect the driver?
    In the end I want a sub that will perform well for movies.
    Thanks for your help.
  2. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    120 liters tuned to 18Hz with a 4" dual-flared port looks ideal for that driver, and will perform better for movies.
  3. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    3,806
    Sorry for not getting back to you Jim sooner...I agree with Jack on the 120 liter box looking better.
  4. JimHal
    Aug 15, 1999
    87
    Will the sound be affected if I don't use "Flares"?
    When you input these parameters into WinISD, the mach rating is .21, this program says this is bad. Does Unibox take any of this into consideration?
    Can I live with this mach rating?
  5. Jack Gilvey
    Mar 13, 1999
    4,948
  6. Andrew Pratt
    Dec 8, 1998
    3,806
    Jim if you order the flares ask them not to ship the tube part but just the ends...no sense paying for a larger box then needed. If you don't want to use the flares then I'd at least use a router and round off the edge where the port exits the MDF...this won't have as big an effect as real flares but its a lot cheaper
