Fallen sonotube
Discussion in 'Archived Threads 2001-2004' started by Jedd, Apr 11, 2002.
  1. Jedd
    Jedd Second Unit
    Feb 5, 2002
    298
    Another idea I have. [​IMG]
    What will happen if I put sonotube (22"x2') on a side?
    I'm trying to remember something from the school physics.. Will the sound pressure keep the rigid form in this case or not?
  2. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,717
    463
    I take it you're worry about some bazooka action going on under intense bassy scenes? [​IMG]
    As long as the endcaps are securely attached to the tube, you shouldn't have any problems on that front.
    You'll have to make some stand/mount with the curvature of the tube factored in so it doesn't roll around the room.
  3. Jedd
    Jedd Second Unit
    Feb 5, 2002
    298
    I'm woried about the whole sonotube concept:
    when the tube does stand as it should the sound makes the same pressure in all directions on the same level, so the tube walls are rigid as a stone.
    I'm not sure, would it keep internal pressure as well in my case or not?
    Anyway I'm about to try it (for the sake of easy amp-flushing and low profile), just hope it wont screw up because of the some physics laws pulling.
  4. Mike Strassburg
    Mike Strassburg Second Unit
    Nov 4, 2001
    421
    Probably be easiest just to make the outer endcaps square, or at least part of them......
  5. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    Jedd,
    Laying the tube on it's side won't affect the internal pressure in the enclosure.
    Brian
  6. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    Jedd
    As others have stated the tube will work fine. That being said realize the tube material is fragile. So avoid impact damge from vacuums, or other things scurrying about the floor etc.
  7. Archer S
    Archer S Auditioning
    Apr 1, 2002
    2
    Re: Sonotube fragility.
    Another hobby of mine that makes extensive use of Sonotube is telescope making. A popular technique used by ATM's to toughen up their sonotube is to coat it with WEST System epoxy. This should make the outer layer tough enough to withstand the occaisional encounter with the vacuum, cats, kids, etc...
  8. ThomasW
    Nov 6, 1999
    2,282
  9. Robert_Gaither
    Robert_Gaither Screenwriter
    Mar 12, 2002
    1,370
    The only other problem I can also see is that Sonotube subs are somewhat light and might dance in a backward/forward motion due to the movement of the cone (a heavily weighted stand and firm mounting is a must).
  10. Jedd
    Jedd Second Unit
    Feb 5, 2002
    298
  11. Patrick Sun
    Jun 30, 1999
    38,717
    463
    If you punched the tube on its side, you can crease it and crumple it. You do that with a piece of wood, and your knuckles will be paying the price.
