Faint horizontal bar problem
Discussion in 'Home Theater Projects' started by RobbieF, Mar 4, 2004.
  1. RobbieF
    RobbieF Extra
    Feb 2, 2004
    15
    I figure this is more of a noise/connection issue rather than a display issue...
    When advancing through the AVIA test patterns with white areas, I notice very faint (slightly darker than white) horizontal bars. These areas seem to shift and move whenever I press forward to advance to the next pattern. They will move slightly during and immediately after pressing "next" on my dvd remote and then stay still.
    They are not all that noticable (can't see anything watching moving pictures on dvds) but it still bothers me. I know it's not just an AVIA thing, it is just easier to see on the white background patterns on this dvd.
    I thought maybe I was picking up noise in the component cables. I recently upgraded from Monster Video 1 cables to Blue Jeans Cable (wasn't sure if the Video 1 had the bandwidth requirement for progressive scan??) and it didn't go away.
    Could it possibly be power related? I am using cheap home surge protectors on everything.
    Equipment:
    Panasonic 53" HDTV (PT-53WXD63)
    Sony DVD player (DVP-NC665P/B)
  2. Dennis Gardner
    Dennis Gardner Stunt Coordinator
    Dec 12, 2002
    206
    Unplug your cable or satellite connection from your TV or receiver while you use the Avia and see this helps. Most horizontal lines are some type of ground loop caused by different grounding throughout your system. If it does help, then you need to check your earth ground where your cable comes into the house. Connections outside have a tendency to come loose or corrode.
    Dennis
  3. RobbieF
    RobbieF Extra
    Feb 2, 2004
    15
    I don't have a cable or satellite connection although I do have an attic antenna connected for OTA HDTV.
    The antenna isn't grounded in any way, just suspended in the attic. I will see if unplugging it makes a difference.
  4. RobbieF
    RobbieF Extra
    Feb 2, 2004
    15
    After doing a little more research on what you said, it is probably the fact that my dvd player is plugged into a separate surge protector than my tv (causing a potential ground loop). It may simply be fixed by plugging them both into the same outlet! I will try it tonight.
  5. Dennis Gardner
    Dec 12, 2002
    206
    Eliminating grounding differences anywhere in your setup usually helps video lines and audio hums.
    Dennis
