factory refurbished - Pronto TS1000
Discussion in 'Archived Threads 2001-2004' started by Ray R, Dec 11, 2001.
  1. Ray R
    Ray R Stunt Coordinator
    Jun 28, 2000
    106
    Should I pull the trigger on a factory refurbished pronto ts1000 for $150 or spend the extra on the tsu2000?
    Are there significant improvements with the tsu2000? I would be using the software to program it, so the fact that the newer model has a codes database doesn't matter that much to me.
  2. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    3,806
    grab a T1000 before they are gone..there's little to be gained in the 2 meg version esp if you are using Pronto edit.
  3. Jeffrey_Jones
    Jeffrey_Jones Second Unit
    Nov 6, 2001
    283
    I would by the TSU2000. It is a second generation product which means that the bugs in previous versions have been fixed. Also it is new. I would not buy a factory reconditioned anything, so I am a little biased. I tried buying the factory reconditioned charger when I purchased my TSU2000 and it didn't work. Very annoying.
    I think the extra memory will be useful especially if you get carried away with channel logos, bitmaps, etc.
    I also think the new unit has better screen contrast...not perfect, but better.
    Jeff
    PS - You can get a new TSU2000 for around $250.
  4. Ray R
    Jun 28, 2000
    106
    Thanks for the input. I decided to give the TS1000 a shot. The only serious issue that the TSU2000 seems to address is the codes database.
    I ordered it from jandr.com if anyone else is interested.
  5. Andrew Pratt
    Dec 8, 1998
    3,806
    Jeff if anything the older pronto's had better screens then the new ones. Most of the bugs you speak of were also taken care of with the various firmware upgrades that are available as well so really the only difference is the built in database and the extra memory. I've got nearly 300 cd's listed in my CCF and still have plenty of memory left.
  6. Pamela
    Pamela Supporting Actor
    Mar 14, 2001
    779
    I bought a refurbished TSU100 from J and R and have had no problems with it. It's been a lot of fun getting it set up. I don't know how I lived without it!
    Enjoy!
  7. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    Now on 3rd J&R refurb- first 2 arrived screwed up (one DOA, one just flashed batteries and shut down everytime used).
    Waiting on the 3rd, hopefully this one will work.
    I would recommend against ordering one, I would just buy a new one, if I were anyone reading.
    -Vince
  8. John Devine
    John Devine Auditioning
    Dec 10, 2001
    9
    On my second Pronto 1000 from J&R
    First one had a dead back light button.
    It is a great remote and I look forward to getting it set up.
    The price is right at 139.00 and with a year warranty I feel safe.
