f38310, problem..help
Discussion in 'Archived Threads 2001-2004' started by Gregory Scott Bass, Jan 5, 2003.
  1. Gregory Scott Bass
    Gregory Scott Bass Stunt Coordinator
    Jun 30, 1997
    180
    i posted this at avs but if anyone here has this set I would appreciate your input. Thanks Scott
    Ok...so I hav'nt finished trouble shooting yet but I thought maybe someone here could help me out, I was watching starwars 2 today at around -10db which is pretty loud through my avr-8000, during periods of major bass thumping my screen is jumping, I tried isolating my center speaker better but it had no effect....so one of two things are happening....either my subwoofer is transfering enough energy through the floor to make my tv innards jigulate or the bass transients are sucking so much power out of the wall it is effecting the tv's power supply, which do you think it is? how much juice does this set take? I ask because when I first got the set my avr-8000 was shutting down at high volume levels...I fixed it by just plugging it in to a different outlet (same circuit breaker though)
    has anyone else made there picture jigulate? [​IMG] thanks Scott
  2. Grant H
    Grant H Cinematographer
    Jul 24, 2002
    2,844
    I confess I never had this problem. I have the same TV. My center channel is pretty big too. Everything's on same circuit (150 watt Subwoofer).
    My building is supposed to have excellent wiring though.
    And everything is double surge protected. I also have heavy duty rubber car mats under my sub to reduce floor vibrations for the sake of my downstaris neighbors.
    I also have the last generation of this TV. I've read earlier models did have power supply problems.
