F/S Linkwitz Transform boards
Discussion in 'Hardware Classifieds' started by AndyHangartner, May 9, 2005.
  1. AndyHangartner
    AndyHangartner Stunt Coordinator
    Jul 8, 2002
    183
    I have two boards that are complete except for the resistors and capacitors for a specific speaker,and the same for the selectable Hi Pass. They have built in power supplies on each board that makes them extremely easy to incorporate. They use the Burr-Brown OPA 2134pa op amp.(the op amps are not mounted, they need to be soldered in or add the 8 -DIP socket so the op amps can just be pressed in).They incorporate an input buffer, a 2nd order High Pass that is user selectable,disabled or select your Frequency by adding resistor and capacitors, and a variable gain pot +/-6dB. These are new and unused. I purchased them for an LT project that is no longer in the works.
    $95 each, shipped to the 48 states.
    pics available
    [email protected]
  2. AndyHangartner
    Jul 8, 2002
    183
    I know that someone is interested in an LT circuit and cant find an over abundance of info or help. I was there. As I stated these are very complete boards with their own power supply and adjustable gains. Great for someone using an older amp or pro amp.
    Make a serious offer, NOTHING ridiculous please.
    thanks
