Eye Strain with my new TV - any ideas?
Discussion in 'Displays' started by Mike_N, Mar 16, 2005.
  1. Mike_N
    Mike_N Auditioning
    Feb 17, 2001
    9
    Hi,
    I just got the Sony KV-32HS420 widescreen tv. It's a 30" widescreen tube tv.
    Here's the situation.
    - Watching regular cable tv (not-digital, not hdtv) is fine on my eyes.
    - Watching dvds causes severe eye strain.
    - TV has been calibrated with Digital Video Essentials.
    - DVD Player - Pioneer DV-578A-S connected with component cables.
    - DVD player is sending out a progressive signal and configured for a widescreen tv.
    - I have tried watching with a dark room and with some lights on.
    - I sit about 7 or 8 feet from the tv.
    The picture looks great, I am guessing maybe the refresh rate of the set is different when it switches to 'dvd' mode? Does the higher resolution alter the refresh rate?
    Does anyone have any ideas? I've watched a 10 year old Sony 27" (4:3) set in the same room for years with no issues at all.
    Any ideas or suggestions would be much appreciated. Should I try letting the dvd send out an interlaced signal and then have the set perform 2:3 pulldown? (CineMotion).
  2. Jack Briggs
    Jun 3, 1999
    16,738
    129
    You may have calibrated that Sony with DVE, but where do you have the so-called "Sharpness" control set? Overdoing the "Sharpness" is a major cause of eye strain.
  3. John S
    John S Producer
    Nov 4, 2003
    5,460
    yeah,, if your sharpness is cranked it can cause it.
    If not try some back lighting behind the set. I have had to do this for a few people and it seemed to help a lot.
    General lights on, does not have the same effect as low level back lighting in my experiences with this.
  4. Mike_N
    Mike_N Auditioning
    Feb 17, 2001
    9
    The sharpness is turned on maybe about 50%.
    I was surprised at this. However, with the sharpness turned all the way down, the sharpness pattern on DVE was way too soft and out of focus. It didn't come into clear focus until around 50%.
  5. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Well, Mike, let's turn it down to, say, 30 percent and then see what happens. If you like it, then go down to 20 percent. The idea is to get it as close to zero percent as possible. On my WEGA, the sharpness is on, but barely. And I see lovely detail.
  6. Barry_B_B
    Barry_B_B Second Unit
    May 14, 2001
    453
    You may want to try a small bias light behind the tv. Also another vote for turning down sharpness as low as possible [​IMG]
  7. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    If your contrast is too high ... then it will cause considerable eyestrain.
    If you set up contrast from a test disc ... chances are ... you set it too high. Like running a car at 5999 rpm because the red line is at 6000 rpm.
    regards
  8. Dave H
    Dave H Producer
    Aug 13, 2000
    5,586
    213
    9,110
    I agree contrast is likely the culprit. Recently, I decided to just raise my contrast a couple of notches and I had to turn it back down again.
  9. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Yes, contrast too. But since he had used DVE, I assumed it was low. So, what is your contrast set at?
  10. Mike_N
    Mike_N Auditioning
    Feb 17, 2001
    9
    Thanks for all of the replies.
    Contrast (Picture as Sony calls it) is turned almost all the way off. If you go into the video menu and select contrast, only 4 bars are on. I could probably lower it a little bit if needed.
    I experimented with the sharpness some more. If I turn it all the way off, the picture gets very soft, fuzzy and out of focus. I'm pretty sure I've got it set correctly.
    My wife watched a movie tonight, and she says her eyes are fine. I'm thinking now the problem may be my eyes or glasses. Perhaps with a bigger screen (and a little closer to the sitting area) my prescription doesn't need to be as strong.
  11. gabrieljosh
    gabrieljosh Auditioning
    Aug 24, 2009
    Sometimes when daily tasks strain the eyes they can develop a particular eye syndrome. When that happens, minor eyestrain can lead to the appearance of real vision problems.
