Brett DiMichele
- Sep 30, 2001
- Brett
What the hell...
So my Behringer Tube Ultra-Q arrived this morning...
Last night I completed the cables I needed to hook this
thing up. The Behringer has inputs and outputs for Ballanced
1/4" Phono, Unballanced 1/4" Phono and Ballanced XLR.
I decided to use Unballanced 1/4" Phono Plugs. 2 Mono
Plugs per RCA Patch Cord equals a stereo pair unless I am
completly brain dead right?
The center pin is the hot, the sleeve is the cold the same
goes for the rca barrels so I know I wired it right..
Well I wire it all up and basicaly it lights up... I have
to crank the incomming gain to even get the VU meters to
move a little... And when I enguage one channel of the
parametric EQ it shuts down a speaker.. When I enguage
both channels I get nothing...
So I am listening to it for a while with the eq section
completely shut off just using the tube output... And
it sounded real "smooth" like they were working...
That was untill I go over to my right speaker only to find
out gee.. my Tweeter fried...
Well isn't that freaking peachy!
No wonder the highs were so "smooth" yeah when your down
to one tweeter....
I don't know if there is a fuse for the tweeter or if there
is some sort of thermal breaker built into the XO I am going
to let it sit for a while and then try it again..
Worst case scenario the tweeter is fried, well the speakers
do have a 5 year warranty so getting a new tweeter from AR
won't be an issue..
But why the hell ain't the Behringer working? If I am getting
a Left and Right signal through, then why does it cut out
the speakers when I enguage the parametric EQ and why the
heck is the input level so low...
The manual sure as heck don't tell me much about how to
wire it up other than "get a professional to install this
unit" well gee.... Can I look "professional" up in the
yellow pages? Hey Professional.. HELP!!!
It says something in the manual about a 6Db Cut and I guess
that's on the unballanced side... Maybe I should have used
the XLR's afterall....
But why did the tweeter fry... Just coincidence?
*rips hair out*
[/End Rant Mode]
to one tweeter....
won't be an issue..
*rips hair out*
[/End Rant Mode]
