External Hard Drive Question
Discussion in 'Archived Threads 2001-2004' started by Tim L, Jul 1, 2002.
  1. Tim L
    Tim L Second Unit
    Jun 30, 1997
    323
    I am looking to purchase an exernal firewire hardrive for a MAc OS9 system- I have never used an exernal dreive and was thinking of getting an Que m3 120gb drive- my questions are is this a good brand and how easy are these puppies to install and use? any input appreciated
    Tim
  2. Michael*K
    Michael*K Screenwriter
    May 24, 2001
    1,806
    I haven't used the QPS (Que) hard drives, but I have used their external FireWire burners and I can tell you the quality is outstanding. That said, you could probably save a few bucks by buying an IDE hard drive and a FireWire enclosure for it. But if you aren't so inclined then the self-contained units work just as well.
    Other than the installation of a possible software driver, the drives are truly plug and play. You just plug it into the FireWire port and it appears on you Desktop as a separate volume. Just make sure when you're done that you "eject" the volume by dragging it to the Trash. Then you can unplug the drive and be on your merry way.
