Jeff Jacobson
- Dec 24, 2001
I am going to buy an External Enclosure and put a hard drive inside of it.
I may want to put a DVD burner in there later, so I'm planning to get a 5.25" enclosure. I also want one with both USB2 and Firewire connections.
This is the one I was thinking about buying: Bytecc ME-340F2U2. Is this a good one? I chose this one because it has 1394B support.
Questions
[*]On NewEgg's site one of the search options is AC Adapter "Yes" or "No".
Which is better? Since the "No" enclosures seem to come with a power cable, and the "Yes" ones came with a power cable that has a big box attached to it, I am assuming that the "No" enclosures have that box built into them. Is that correct?[*]Is a USB2 / 1394B enclosure compatible with a computer that only has USB1 and 1394a connections? (I realize that I can add USB2 and 1394B support to my computer with a PCI card, but I want to be able to use the enclosure with other peoples' computers without having to install a PCI card. Also, by only adding one new component to my computer, if something doesn't work I will know which component is at fault.)[*]I remember reading somewhere that the "Oxford" chipset was the best.
That was a while ago that I read that, so is that still true? (I'm not sure what chipset is used by the Bytecc ME-340F2U2.)[/list]
Questions
