External DVD with PC firewire support?
Discussion in 'Archived Threads 2001-2004' started by GregK, Jun 20, 2002.
  1. GregK
    GregK Screenwriter
    Nov 22, 2000
    1,037
    311
    1,610
    Are there any DVD burners that have a firewire jack that
    could interface with a PC? This way I could burn my own
    DVD-Rs (or DVD+RWs) right out of the box using the analog
    inputs, but I could also back up or transport PC files
    through the firewire jack. ..Or I could produce more
    elaborate DVDs with picture menus or even a commentary
    track directly from my PC in the future. I could also make
    perfect clones of my own home brewed discs by using a simple
    mirroring program. Commercial DVD's have digital copy
    protection, so "abuses" also shouldn't be an issue.
    ..Or have the paranoid Hollywood studios made a valuable
    feature like this a "no-no" as well? [​IMG]
  2. Jeff Kleist
    Dec 4, 1999
    11,267
    I don't quite understand what you're asking
    If you're asking if there are any stand-alone DVD Recorders with firewire jacks, the answer is no, and nor are there every likely to be. You couldn't send files through those anyway.
  3. Eugene Hsieh
    Eugene Hsieh Supporting Actor
    Jun 30, 1997
    550
    First off, this may be in the wrong forum.
    Are you talking about set top recorders or standard Firewire PC burners?
    If set top recorders basically what you can do is create videos and output the video stream to the set top recorder, but AFAIK there aren't any that let you use it as a standard computer burner for your PC-authored DVDs. (Jeff, they do have Firewire connections.)
    If external Firewire PC DVD burners are what you're talking about, there are a bazillion of these.
    If I'm reading you right I think you want BOTH a set top DVD recorder and a computer DVD burner (internal or external).
  4. GregK
    GregK Screenwriter
    Nov 22, 2000
    1,037
    311
    1,610
  5. Jeff Kleist
    Dec 4, 1999
    11,267
    They don't exist
    You need to get either a DVD Burner or a set top dvd recorder
    Such an animal would be spiffy, but I don't even want to think about the lawsuits a-coming on something like that [​IMG]
  6. Eugene Hsieh
    Jun 30, 1997
    550
