Exterior car care products.
Discussion in 'Archived Threads 2001-2004' started by Stephen L, Apr 4, 2002.
  1. Stephen L
    Stephen L Second Unit
    Jan 3, 2001
    358
    With so many different products on the market I'm just curious what everybody uses for wash,wax and tire treatments.
  2. Daniel Swartz
    Daniel Swartz Second Unit
    Mar 3, 2002
    448
    Zaino (series of products) on a 2001 E46 330i BMW.
  3. Shawn C
    Shawn C Screenwriter
    May 15, 2001
    1,429
    Zaino. The stuff actually works. I use it on my 98 Montero, my 01 Neon and my 00 Honda Valkyrie.
    It gives an amazing shine.
    http://www.zainobros.com
  4. Scott Merryfield
    Dec 16, 1998
    12,623
    1,279
    9,110
    I've used several brands of non-abrasive wax -- the latest was Nu Finish (it's supposed to be a once-a-year wax). I use Armour All products for the tires, aluminum rims and interior, and Rain-X for windows.
    I've never heard of Zaino. Can this be purchased at a retail store, or do you have to order it direct from the manufacturer?
  5. BrianW
    BrianW Cinematographer
    Jan 30, 1999
    2,563
    38
    Brian
    I use http://www.buffalomilke.com/ with very impressive results. It's a spray-and-buff liquid wax that doesn't leave a haze. It's a "go anywhere" wax, meaning it's suitable for rubber and plastic, which makes it great for motorcycles, since you don't need to discriminate which surfaces it comes in contact with.
    I've used Nu-Finish, but I'm not nearly as impressed with it as I am with Buffalo Milke.
  6. Lary Larson
    Lary Larson Stunt Coordinator
    May 3, 1999
    77
    I also use the Zaino series on my '95 Lexus SC400. It looks better than new when I'm finished.
    Scott - there are a few retail distributors for Zaino, you have to email Zaino to find out if there's one near you. I just ordered direct from Zaino.
    Lary
  7. Mike I
    Mike I Supporting Actor
    Jan 20, 2000
    720
    I agree with the Zaino replies..The stuff is great...
  8. Brian Mansure
    Brian Mansure Second Unit
    Mar 15, 2000
    460
    I'm suprized no one has mentioned Mequiars Car Care Products. http://www.meguiars.com/
    I've used their wash and wax stuff for years on all different types of cars, old and new, all came out looking great once I was finished.
    One of the car wash/wax products I will never do without is called the "absorber". It's a synthetic chamois that cuts down drying time by at least 50 percent, so no water marks.
    I've also started using the "California Duster" for both light cleaning of the exterior and interior of my car.
    Brian
  9. Howard Williams
    Howard Williams Supporting Actor
    Mar 7, 2001
    521
    Another Zaino freak here !!! (Z1,Z2,Z6,Z7,Z18)
    1999 Silver/Silver S-420 Mercedes Benz.
    I can make someone a pretty good offer on the ZFX and Z5. I bought the ZFX and the Z5 but I don't think I'm going to use them. It's a long story. If interested, let me know.
    It's too early for me to tell but from what I hear Zaino lasts much longer than even the best waxes from Mequiars.
    Zaino RAWKZ !!!
    I use Mequiar products for the interior and tires. Gold Class leather cleaner & conditioner, Natural shine vinyl & rubber protectant, Gold Class Endurance for tires.
    I just got a California Water Blade and California Dusters (large & small). Haven't had a chance to break those puppies in yet.
  10. Shawn C
    May 15, 2001
    1,429
    I'll second the 'absorber'. They work great for drying your car. They have those at Wal-Mart, Target, wherever
    I will also second the California Dusters. I use the Dash Duster on my motorcyle all the time. Most of the time, my motorcycle doesn't get dirty, just dusty. The dash duster works perfect.
  11. Zen Butler
    Zen Butler Producer
    Jan 24, 2002
    5,548
    20
    6,610
    Southern, Ca
    Zen K. Butler
    I actually use Finish 2001 for a polish. Then either a Meguiars carnuba or The Wax Shoppe as a wax. Harlys for tires and interior.
  12. Shawn C
    May 15, 2001
    1,429
    Howard, I got the notification that you sent me an e-mail, but i can't login to Hotmal right now. I will get back to you asap as soon as I can login.
  13. Brian Perry
    Brian Perry Cinematographer
    May 6, 1999
    2,807
    For cleaning road tar from the lower sections and also for brake dust, I use Simple Green. It works great and I think it's mild enough not to damage your clear coat.
  14. Andrew W
    Andrew W Supporting Actor
    Jun 19, 2001
    531
    Zaino!
    [​IMG]
  15. Mark Leiter
    Mark Leiter Second Unit
    Aug 9, 1999
    387
    Only Zaino's goes on my vette!!!!
    Great stuff
  16. Michael Bermudez
    Dec 30, 1998
    17
  17. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    help! (i learned my lesson the hard way.)
    i usually use this glaze from a company called (i think) The Wax Shoppe. stuff works great and can go on anywhere.
    anyway...
    i decided to wax my car with some crappy turtle-wax stuff at my girlfriends. it went on tough and came off even tougher. now i have dried wax "deposits" in some of the nooks and crannies of my dark-green honda, plus it screwed up some of the rubber moulding. [​IMG]
    does anyone know of anything i can do to fix this? several people told me i could rub peanut butter (smooth) on the rubber part, but i haven't tried it yet. the only thing i can think of to get the wax deposits off is some sort of hard plastic (obviously not metal) device, but nothing comes to mind. toothpicks are too weak.
  18. Howard Williams
    Mar 7, 2001
    521
    Ted:
    I'm sure no expert but Dawn (liquid dishwasing detergent) is recommended by Zaino to remove old wax. It's is suppose to be very alkaline. Maybe a couple of good washing with it might help.
    Many people say use a toothbrush to remove wax from knooks and crannies. Some people say a toothbrush can sctrach.
  19. Scott_G
    Scott_G Second Unit
    Jun 18, 2000
    268
    My 540 gets Mequiars 26.
  20. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    thanks howard -
    maybe i'll give it a good soaking with dawn. by now, the stuff is pretty crusted on, so i'm pretty sure a toothbrush won't work. but maybe i can file down the handle of of one to use as a scraper! hmmm....
