Extending component cables? How?
Discussion in 'Displays' started by Scott Stephens, Apr 28, 2005.
  1. Scott Stephens
    Scott Stephens Stunt Coordinator
    Dec 23, 1999
    130
    i need about 20-25 ft of component cable to connect a DVD player to my plasma in my office. i found 15 ft component cables, but can't find any longer than that.
    what's the best way to couple these? i'm looking for a female/female connector, but i'm unsure of what to buy. can i use regular RCA f/f? any help would be appreciated. thanks.
  2. Benson R
    Benson R Supporting Actor
    Mar 24, 2000
    741
    I used some female to female rca interconnects for a while, and that worked fine.
    I eventually found a 25 foot cable online, I dont recall where offhand, but I believe some htf sponsors sell components cables in that length and greater.
  3. Mike.N
    Mike.N Extra
    Apr 26, 2005
    15
    When I moved I needed a longer conponent cable and did the same as Benson. Works great PQ just fine. My run is 20'.
  4. John S
    John S Producer
    Nov 4, 2003
    5,460
    Circuit City sells GE cables (look hard, they hide them sort of)... I use the 25' a lot. Way less than $30 for them.
  5. Jerome Grate
    Jerome Grate Cinematographer
    May 23, 1999
    2,984
    6
    110
    I agree with Benson and Mike, I'll even take it a step further by suggesting you pick up 25' shielded Coax cable along with some RF to RCA connectors and some color tape.
  6. John S
    John S Producer
    Nov 4, 2003
    5,460
    RG6 makes the most awesome Component Video cables hands down at any price in my opinion.
    I have solved a fair amount of pesky interference issues by going to it, even over the prized monster cables.
  7. Jerome Grate
    May 23, 1999
    2,984
    6
    110
    I Agree, RG6 coax cable is used for satellite and digital cable.
  8. DanielJW
    DanielJW Extra
    Apr 16, 2004
    20
    I bought my component cables from here. I bought the 50-footer for less than BB/Circuit City sells the 25'. The quality of the cables and service from the company is spectacular, and I was happy to find cables with a white coating which are more living room friendly and don't stick out like black ones do.
    My two cents.
    Daniel
