Brian Cal
- Nov 13, 2000
With my brand new Panasonic CP72 DVD player and Pioneer VSX-D811S receiver I figured it was high time I checked out DVD-Audio, so I bought Steely Dan "Two Against Nature" and had a go at it. I think I did everything right, but just want to make sure I have the setup procedure correct.
First, I hooked up 6 analog RCA cables from the Panasonic to the analog 5.1 input jacks on the Pioneer. I then set the Pioneer to "DVD/LD 7.1" analog input. On the Panasonic, I set "PCM Downconversion" to "No", because I was under the impression that "Yes" somehow degrades the signal. Speaker setup on the Panasonic was set to "Multi-Channel", but I left all of the speaker sizes, level controls, and delay settings at 0, because I was told that they have no bearing whatsoever on DVD-Audio.
Everything seemed to be set up correctly when I played the first track. I checked the audio being output from the Panasonic and it said "PPCM - 96k/24b 6 channel". Contrary to what I had heard, I could adjust the individual channel levels on the Pioneer, but what struck me as odd is that I usually have my sub set at -8 for DTS and DD, but with DVD-Audio I had to turn it all the way up to +10 to get a respectable level of bass. I realize that I do not get bass management with DVD-Audio, but it seems rather extreme that I had to turn the LFE channel up a whopping 18 dB. My main speakers are JBL S38, my center is the S-Center, and the surrounds are the N24, all of which (I thought) are capable of handling more bass than what I was being given.
Other than the bass issue, everything sounded great. I have never heard cymbals sound so crisp and lifelike. Most impressive was how realistic everything sounded, as if the musicians were in the same room as me.
Sorry to ramble, but from what I heard last night, this is an incredibly exciting audio format, and I just wanted to make sure that I didn't miss a crucial step in the setup procedure. Perhaps I am missing something in the bass setup, since an 18 dB boost for my sub seems a bit excessive, especially with semi-large speakers all around. Thanks for the feedback, I hope I'm posting in the right forum :b
