Expanded 4:3?
Discussion in 'Displays' started by MattGentry, Sep 19, 2003.
  1. MattGentry
    MattGentry Second Unit
    Apr 22, 2003
    257
    On the TV I am looking at (a Philips 27")...I was checking out the menu at Best Buy and discovered something. On it, it had some sort of aspect ratio change from 4:3 to expanded 4:3.
    So my question: what does expanded 4:3 mean?
    Thanks...
  2. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    I would guess that it expands (zooms) a 4:3 frame containing a letterboxed wider aspect ratio picture, and some of the black top and bottom areas and also some of the sides get cut off.
    Did you try the expanded 4:3 on the TV right there in the store?
    Video hints:
