Exactly how do receivers and extrnal amps work together?
Discussion in 'Archived Threads 2001-2004' started by Tim_R_H, Feb 26, 2002.
  1. Tim_R_H
    Tim_R_H Stunt Coordinator
    Feb 12, 2002
    51
    I know this is probably a stupid question, but I'm trying to figure out how these things work.
    If you have a 100 watt per channel receiver and you add a 5 channel amp at 80 wpc does it increase your per channel power to a total of 180 watts or are you bypassing the internal amp and getting 80 wpc from that external amp only?
  2. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
  3. KyleGS
    KyleGS Second Unit
    Feb 12, 2002
    342
    I guess Vince summed it all up in those links [​IMG] Thanks Vince- very informative to this new newbie.
  4. Tim_R_H
    Feb 12, 2002
    51
    Thanks for the links Vince!
    Some related questions.
    1. So is an external amp always going to give you better quality sound and more power even if its wpc is rated lower than your receiver?
    2. In one of the links it mentioned that 4ohm speakers needed twice as much power as 8 ohm speakers. I would assume then that 6ohm speakers would take 1 1/2 times more power. If this is the case then my 120 wpc receiver isn't truly going to give me 120 wpc unless I am using 8ohm speakers and in fact may only give me the equivilant of 90 wpc when used with my new PSB speakers which are 6ohm. Is this correct?
  5. Vince Maskeeper
    Jan 18, 1999
    6,499
  6. Jack Briggs
    Jun 3, 1999
    16,738
    129
    And as a brief coda to the matters discussed ...
  7. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    2
  8. Tim_R_H
    Feb 12, 2002
    51
    Personally I believe a stupid question is usually one that is asked after the problem has occured which is what I am trying to avoid.
    My Kenwood 1080VR receiver only refers to the channels being driven 120 W each at 8 ohms so should I keep a fire extinquisher near by?[​IMG] or better yet use this as an excuse to my wife that I need to upgrade my receiver now due to my ignorance?
  9. Tim_R_H
    Feb 12, 2002
    51
    I called Kenwood technical service and the guy said I should be fine under normal listening conditions. He also said the reciever will automatically power down if it can't handle the load.
