Matt Heebner
- Jul 2, 2000
I just picked up the Evil Dead 2 DVD,the one with the THX certification and Roger Eberts rating on the front, and AoD (or actually Bruce Campbell vs. Army of Darkness) Bootleg cut.
I did a search of this to find out if I had made the right choices in getting these movies since there are so many different versions out there. After the search, I am more confused than ever, and would like a little advice.
Are these two versions decent enough to keep, or are there better versions out there? I dont want to open them up if thats the case so the can be returned, and exchanged. My friend said that the commentary on both is pretty excellent, so I am definitly interested in that and both movies I bought have commentary. I had no idea that there were a bizillon versions out there.
Any advice or suggestions? Did I get the bad or the good versions of both? Is there better?
Matt
Matt
