European DVD in US (1 Viewer)
Chris_FFF
Grip
Help, just bought a DVD from Europe, how can I make it work in my player? Is it possible? Or, can I somehow get it on my computer then reburn it to US format? Thanks!
Chris_FFF
Grip
not really sure, 1st time coming across this. My DVD player says "cannot play this disk" the disk says
DVD 9 PAL 4:3 Hope that helps! Thanks again
JohnAD
Chris:
You need a player that will both play Region 2 titles, and convert a PAL signal to NTSC. I would suggest a Malata 520,
but there are a few others out there that will do it. Another option would be to switch your computer's DVD drive to Region 2, although you can only do this a limited number of times.
John.
RobD
I assume defeating regions is an OK topic, so here goes.
Disclaimer: Not my faul if any of this causes problem (Worked for me) ;)
For your PC just download a region free firmware for your DVD drive and then install DVD Genie (Be Careful to download the correct firmware and follow the instructions exactly).
Link:
http://www.rpc1.com
To defeat region locking on a seperate dvd player I need to know the exact model and brand. The initial problem is a region lock, will deal with PAL (If it is a prob) later.
Chris_FFF
Grip
Ok, great! Thanks. I'll let you know when I get all that done. Off to work for now. Thanks again, I thought I wasted my $$ on these disks.
Chris_FFF
Grip
Also, I have access to a DVD player on my girlfriends computer, this one here is only a cd drive and cd burner that comes standard with a Dell (LG CD-RW CED 8080B) and a (LG CD-ROM CRD-8482B) if that means anything to you guys. So I was wondering if this disk can be transferred here or must be done at her house on her DVD player. Thanks again!
Chris
yacubjkc
