ethernet cable
Discussion in 'Archived Threads 2001-2004' started by Anthony Moore, Apr 19, 2002.
  1. Anthony Moore
    Anthony Moore Supporting Actor
    Jul 12, 2001
    707
    Does the length of an ethernet cable matter? I was under the impression that as long as it was less than 100 meters, there would be no difference in speed. But after 100 meters, the speed would drop off.
    Is this true? If you know of a site that will inform me, please link me.
    any help would be appreciated
    thanks
  2. Matt Stryker
    Matt Stryker Screenwriter
    Oct 12, 2000
    1,307
    After 300 feet or so, you start to get enough attenuation to affect the signal; it can cause speed loss or complete cable failure.
  3. Keith Outhouse
    Keith Outhouse Stunt Coordinator
    Feb 2, 1999
    91
    http://www.faqs.org/faqs/LANs/ethernet-faq/index.html
    [3.11] What is propagation delay?
    The propagation speed of a medium refers to the speed that the data
    travels through that medium. Propagation delays differ between
    mediums, which affect the maximum possible length of the Ethernet
    topology running on that medium.
    In the following table, c refers to the speed of light in a vacuum,
    or 300,000 kilometers per second.
    Medium Propagation Speed
    Thick Coax .77c (231,000 km/sec)
    Thin Coax .65c (195,000 km/sec)
    Twisted Pair .59c (177,000 km/sec)
    Fiber .66c (198,000 km/sec)
    AUI Cable .65c (195,000 km/sec)
    From these values, the size of a bit on 10BaseT can be calculated.
    10BaseT is twisted pair, which has a propagation delay of 177,000
    km/sec. 177,000 km/sec divided by 10 million bits per second is
    17.7 meters, or the size of a single bit on a 10BaseT network.
    The maximum propagation delay through the network can be calculated
    by dividing the maximum length by the speed. For 10Base2 thin coax
    network, this is 185 meters divided by 195,000 km/sec, or 950
    nanoseconds. If the actual propagation delay from one end of the
    network to the other is greater than 950 nanoseconds, late
    collisions may occur. See section [5.4] for more information on
    late collisions.
  4. Shayne Lebrun
    Shayne Lebrun Screenwriter
    Jun 17, 1999
    1,086
    After 100 meters, you DEFINATELY get signal degredation. Before that, it depends on cable quality, where it's laid, how it's curved, how it's crimped, and blah blah blah.
