ESPN2K5 - Saving and Loading
Discussion in 'Gaming' started by JoseEduardo, Sep 6, 2004.
  1. JoseEduardo
    JoseEduardo Second Unit
    Jan 24, 2002
    254
    This might sound like a stupid question, but how do you save your season (franchise?) when you're done playing and then where do you go to load it when you want continue playing? I can not figure this out.
    Thanks!
  2. James T
    James T Screenwriter
    Aug 8, 1999
    1,643
    Don't feel dumb, because I played a game, turned off my Xbox, and was frustrated when I couldn't reload it.
    To Save
    Go to the options, save franchise.
    To Load
    Same as saving, except you'll probably be in the main screen.
    It's a lot of saving/loading for the game. There's profiles, music and franchises. There's probably more, but that's all I ran into.
  3. JamesED
    JamesED Second Unit
    May 23, 2004
    263
    Can you play two different fanchises on the same hard drive, like can you select which file to save over?
    I have to play on my roommate's xbox, but I would love to play it on the Gamecube in my room. Damn them for skipping the cube.
  4. Manuel
    Manuel Stunt Coordinator
    Jun 29, 1999
    199
    yes you can have many season/franchises on the box, just give them a different name when you save
