ESPN 2K5 Xbox Live controls
Discussion in 'Gaming' started by JoseEduardo, Aug 28, 2004.
Tags:
  1. JoseEduardo
    JoseEduardo Second Unit
    Jan 24, 2002
    254
    Hello! I just got this game for $14.99 @ Best Buy, great game for the money!!!! I'm confused however as to which botton to press to talk during LIVE play, I can't get my opponents to hear what I'm saying. Also, is there a way to look at your ranking and stats directly? I've tried reading the manual for this information but it doesn't say anything.
    Thanks!
  2. David Galindo
    David Galindo Screenwriter
    Mar 30, 2003
    1,264
    First, make sure you Xbox communicator is not muted (red). Make sure the option is set to the headset mode, instead of "voices thru speaker".
    I had trouble with this as well in ESPN, though I had trouble hearing the opponent instead of the opposite.
  3. BrianB
    BrianB Producer
    Apr 29, 2000
    5,205
    ESPN likes to reset those options too if you play the offline game without the communicator plugged in. That's caused me problems.
  4. chiante
    chiante Agent
    May 12, 2002
    44
    You can save your online options. There is a section while online that you go in to do this.
  5. BrianB
    BrianB Producer
    Apr 29, 2000
    5,205
    And even if you save, if you load it up without the communicator, it will reset the voice options.
  6. Christop_Holmes
    Christop_Holmes Stunt Coordinator
    May 31, 2003
    55
    Very good game indeed [​IMG] yeah just do what david said, if that doesnt work... most likely somethings wrong with your headset?
  7. Damien
    Damien Supporting Actor
    Mar 29, 2002
    508
    if you want to see your stats create a match and right click on your gamertag.
  8. Jay Mitchosky
    Jay Mitchosky Producer
    Sep 6, 1998
    3,729
    Christop
    Great sig (can I guess at the Photoshop technique - some render clouds and find edges to start?). Could you please save it at a lower res or higher compression to bring it down below the 40M size limit (it's currently at 92M). Looks awesome though.
  9. Christop_Holmes
    May 31, 2003
    55
    nope jay- just did some gradients, and found edges, then overlay and did some more gradients [​IMG]... yep ill work on lowering the size [​IMG]
  10. Jay Mitchosky
    Sep 6, 1998
    3,729
    That makes more sense given the forms are so linear. I'm sure I did something like that in a PS tutorial once.
