Equipment Rack (1 Viewer)
Jack Hogoboom
Jack
Need a recommendation for an equipment rack for my home theater system. It will be in a closet and I'd like to be able to pull it out and spin it around if necessary.
Jack
Adam Gregorich
The Other Washington
Adam
If it can be on the floor, I would get the Sanus Euro racks. They aren't horrible expensive, are very well built, you can add on shelves as you need them, and there is a castor kit available so you can wheel it out of the closet or spin it around. Just make sure that you leave enough wire coming through the back so you can spin it around or pull it out.
http://www.sanus.com/cgi-bin/web_sto...=3970782_29109
tcbkf
