Equipment rack... How big should the shelves be?
Discussion in 'Home Theater Projects' started by Alex-F-V, Sep 5, 2003.
  1. Alex-F-V
    Alex-F-V Stunt Coordinator
    Jul 22, 2003
    81
    I just got a couple of beautiful pieces of wood that I want to make in a audio rack.
    And they are 31 1/2" wide and 6' long.
    I want to use the 31 1/2" side as the fronts of the rack but how deep should I make the shelves?
    I want to make them deep enough to recieve any piece of future electronics that I might buy, regardless of what I have now.
    So essentially all of the shelves will be 31 1/2" x ????
    Thx alex
  2. Joe Hsu
    Joe Hsu Supporting Actor
    Jul 2, 2001
    812
    Wow...I could be wrong, but that should be more than enough space. The rack that I just built had each shelf at 21*23...the receiver's a little snug (as it's supposed to be), with only an inch on each side til you hit the legs, but depth-wise, nothing really gets close to the back-edge of the 21"s. You could make it 24" deep, thus giving you exactly 3 shelves per 6' of wood...?
    Good luck on the project, don't forget to snap lots of pictures [​IMG]
  3. Bob Kavanaugh
    Bob Kavanaugh Second Unit
    Jan 17, 2003
    282
    24 might be a little deep, depending on your preferences. 31 1/2 is certainly too wide for my taste, since standard component width is only 17".
    My stand is 24" deep only because my tv sits on it.
    Here is a pic from the side of my stand, in the front (black) is my Sony 2ES receiver and in the back (grey) is a Sony DVP-NS715P dvd player. Lots of room.
    My vote is for 20 inches deep and something narrower than 31 1/2 inches wide.
  4. Allen Ross
    Allen Ross Supporting Actor
    Sep 30, 2002
    819
    i think my flexy is around, 24X18, its plenty deep for my stuff, so i am happy
  5. Bob Kavanaugh
    Jan 17, 2003
    282
    Allen, by "stuff" you mean your microwave, right? [​IMG] [​IMG] [​IMG]
  6. Allen Ross
    Sep 30, 2002
    819
  7. MikeTC
    MikeTC Stunt Coordinator
    Aug 3, 2000
    63
    I vote for 24" deep because you may needed down the line. Some components such as receivers, Amps and DVD (300+ disc) players are about 21 to 23" deep. When you start adding the connectors to them, 24" is about right.
  8. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    3,806
    Standard width would be 19" to allow for gear with mounting rails on the side so I'd go 20" wide by 24" deep. That's very deep but you might find it useful if you start adding CD jukebox's since the Sony's at least are quite long.
  9. Alex-F-V
    Jul 22, 2003
    81
    Haven't check this till now.... but whoa!
    So many opinions!!!! I decide the 31" is too wide and will Probably gor for about 24"-26" wide, and likely 20" deep, a happy medium I believe.
    But one last question... How high for each shelf? I haven't decided to go flexy style or a fixed version. If I go with fixed how high?
  10. Allen Ross
    Sep 30, 2002
    819
    i would go a little wider then 20.
    my only reason, if you want to get rack components, you want them in some sort of case (at least i did) so if you make a case that is say 1 inch thick one each side, you are now looking at 21 inches, and if you do a flexy, thats internal pole placement, so you are looking at 23-24 inches over all, and with that you will just be able to sqeeze the case through the front.
    i just realized what i all said is mute considering if you go 24 deep, your case prob won't be 24 deep so you could slide it in from the side.
    oh well, i always go for the "bigger is better" theorem
