Steve Morgan
Okay here's the deal.I have 2 subs a SVS20-39cs and a Paradigm Servo 15a.My speakers L/R/C are capable of bass to the mid 30hz,the surrounds are capable of bass to 40hz. My Pre/pro is the B&K REf 30 with good bass management.With the help of a HT member I tracked my SPL levels from 70hz which is my crossover point down to 20hz.A spread sheet was made and my problem was in the 50hz to62hz range with the notch fliter in the Ref 30 I applied a -8db nothch to the 51.3 to 66.7 range. My other problem was at 22hz where I was 15db below average.The most I could do was add a 6db boost to the 20hz range.Chris's spread sheet showed after I applied the notch and the 6db. boost my average was 76.76db.My question is do I need a equalizer such as the Bijou or the Rane 44 or something more simple? My room is 27'x14' with 8ft. ceilings a open dining room that is 13'x13' on one end and a hallway on the other.Due to SO and room contraints my speakers are not in the ideal spot. Any advice and feedback is appreciated
